17 ;;; fix trouble with opening some sites
chain=forward action=change-mss new-mss=clamp-to-pmtu passthrough=no
tcp-flags=syn protocol=tcp out-interface=ether1 tcp-mss=1300-65535 log=no
log-prefix=""
18 ;;; fix trouble with opening some sites
tcp-flags=syn protocol=tcp in-interface=ether1 tcp-mss=1300-65535 log=no
log-prefix=""
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=45.154.хх.хх pref-src="" routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=yes distance=1 dst-address=77.88.хх.хх/24 gateway=172.16.10.1 pref-src="" \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.3.0/24 gateway=10.0.49.11 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.6.0/24 gateway=10.0.49.14 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.7.0/24 gateway=10.0.49.15 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.8.0/24 gateway=10.0.49.16 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.9.0/24 gateway=10.0.49.17 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.10.0/24 gateway=10.0.49.18 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.12.0/24 gateway=10.0.49.20 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.13.0/24 gateway=\
192.168.5.172 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment="*********" disabled=no distance=1 dst-address=192.168.15.0/24 gateway=\
172.22.22.2 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=213.180.хх.хх/32 gateway=\
172.16.10.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=213.180.204.242/32 gateway=\
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=45.154.хх.хх pref-src="" \
routing-table=ISP1-Route scope=30 suppress-hw-offload=no target-scope=10
routing-table=ISP2-Route scope=30 suppress-hw-offload=no target-scope=10
routing-table=ISP3-Route scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=172.16.10.1 pref-src="" \
routing-table=Yandex-Route scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=5.255.хх.хх/24 gateway=\
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=77.88.хх.хх/24 gateway=\
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.88.0/24 gateway=172.22.23.2 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.2.0/24 gateway=10.0.49.12 \
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=193.200.хх.хх/32 gateway=45.154.хх.хх \
pref-src=45.154.116.xx routing-table=main scope=30 suppress-hw-offload=no target-scope=10
