как в скрипте нажать кнопочку disconect/connect на рисунке вот
а скриптом как ее наживать?
# apr/11/2020 16:18:27 by RouterOS 6.46.4
# software id = KXFC-MLNA
# model = SXT G-2HnD r2
# serial number = 698C07D69A2B
add name=bridge1
set [ find default-name=wlan1 ] country=russia4 disabled=no frequency-mode=\
manual-txpower mode=station-pseudobridge ssid=Rostelecom_UUS tx-power=11 \
tx-power-mode=all-rates-fixed wireless-protocol=nv2-nstreme-802.11
set [ find default-name=ether1 ] speed=100Mbps
/interface list
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.33-192.168.88.128
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 disabled=yes interface=wlan1
set discover-interface-list=all
/interface list member
add list=LAN
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
add address=192.168.88.1/24 interface=ether1 network=192.168.88.0
add disabled=no interface=wlan1
add address=192.168.64.0/19 gateway=192.168.88.1 netmask=19
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
set servers=8.8.8.8
add action=drop chain=input protocol=tcp src-address=!192.168.88.0/24 \
src-port=8261
/ip firewall mangle
add action=change-ttl chain=prerouting new-ttl=increment:1 passthrough=yes
add action=masquerade chain=srcnat out-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
set time-zone-name=Asia/Yakutsk
/system identity
set name=home73
