Роутер Mikrotik hAP ac².
Абсолютно хаотичным образом (может несколько раз подряд, а может вообще ни разу за день) роутер сбрасывает все вайфай соединения после начала воспроизведение онлайн видео (не важно ютуб или другой ресурс). после восстановления вайфая все может работать нормально (обычно), а иногда опять сбрасывает.
18:34:20 system,info,account user admin logged in from 192.168.88.234 via winbox
18:35:47 wireless,info E8:4E:06:53:BA:22@wlan1: reassociating
18:35:47 wireless,info E8:4E:06:53:BA:22@wlan1: disconnected, ok
18:35:47 wireless,info E8:4E:06:53:BA:22@wlan1: connected, signal strength -48
18:35:51 wireless,info 7C:76:68:8F:7E:B5@wlan1: reassociating
18:35:51 wireless,info 7C:76:68:8F:7E:B5@wlan1: disconnected, ok
18:35:51 wireless,info 7C:76:68:8F:7E:B5@wlan1: connected, signal strength -52
18:35:56 wireless,info A4:45:19:69:E0:D4@wlan1: disconnected, received deauth: cla
ss 3 frame received (7)
18:35:59 system,info,account user admin logged out from 192.168.88.234 via winbox
18:35:59 wireless,info A4:45:19:69:E0:D4@wlan1: connected, signal strength -49
18:36:00 dhcp,info defconf deassigned 192.168.88.228 from A4:45:19:69:E0:D4
18:36:00 dhcp,info defconf assigned 192.168.88.228 to A4:45:19:69:E0:D4
18:36:38 wireless,info 5C:E0:C5:12:6D:2B@wlan1: disconnected, extensive data loss
18:36:53 wireless,info 18:F0:E4:3C:4B:22@wlan1: disconnected, extensive data loss
18:37:19 wireless,info 18:F0:E4:3C:4B:22@wlan1: connected, signal strength -56
18:37:20 dhcp,info defconf deassigned 192.168.88.230 from 18:F0:E4:3C:4B:22
18:37:20 dhcp,info defconf assigned 192.168.88.230 to 18:F0:E4:3C:4B:22
18:38:54 wireless,info 5C:E0:C5:12:6D:2B@wlan1: connected, signal strength -57
# dec/18/2020 19:12:13 by RouterOS 6.46.8
# model = RBD52G-5HacD2HnD
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=2ghz-b/g/n country=ukraine \
disabled=no disconnect-timeout=15s distance=indoors frequency=auto hw-retries=15 installation=indoor mode=ap-bridge ssid=\
EvilZone station-roaming=enabled tx-power=18 tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=no_country_set distance=\
indoors frequency=auto frequency-mode=manual-txpower mode=ap-bridge ssid=EvilZone station-roaming=enabled wireless-protocol=\
802.11
/interface wireless nstreme
set wlan1 enable-polling=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" group-key-update=1h mode=dynamic-keys supplicant-identity=\
MikroTik wpa-pre-shared-key=**** wpa2-pre-shared-key=*****
Что это может быть?
