Capsman Visio Script
Здесь выкладываем скрипты
Sertik
Script to display clients in WLAN
https://forum.mikrotik.com/viewtopic.ph ... 13#p883975
:global fill do={
    :local STR  $1
    :local LEN  $2
    :local CHAR $3
    :if ([:len $STR] >= $LEN) do={
        :set STR "$[:pick $STR 0 ($LEN-1)]$CHAR"
    } else={
        :for i from=1 to=($LEN-[:len $STR]) step=1 do={
            :set STR "$STR$CHAR"
    :return $STR
:put "$[$fill "MAC" 19 " "]$[$fill "IP" 17 " "]$[$fill "Client" 12 " "]$[$fill "AP" 10 " "]$[$fill "Signal" 7 " "]$[$fill "SSID" 18 " "]$[$fill "TX Rate" 11 " "]$[$fill "RX Rate" 11 " "]$[$fill "Uptime" 14 " "]$[$fill "Bytes" 21 " "]$[$fill "Packets" 15 " "]Interface"
/caps-man registration-table
:foreach i in=[find] do={
    :local locMAC    [get $i mac-address]
    :local locInt    [get $i interface]
    :local locSSID   [get $i ssid]
    :local locSignal [get $i rx-signal]
    :local loctxRate [get $i tx-rate]
    :if ([:find $loctxRate "-" -1] > 0) do={:set loctxRate [:pick $loctxRate 0 [:find $loctxRate "-" -1]]}
    :local locrxRate [get $i rx-rate]
    :if ([:find $locrxRate "-" -1] > 0) do={:set locrxRate [:pick $locrxRate 0 [:find $locrxRate "-" -1]]}
    :local locUptime [get $i uptime]
    :set   locUptime [:pick $locUptime 0 [:find $locUptime "." -1]]
    :local locBytes  [get $i bytes]
    :local locPack   [get $i packets]
    /caps-man interface
    :local locMasterInt [get [find where name=$locInt] master-interface]
    :local locRadioMAC  "00:00:00:00:00:00"
    :if ($locMasterInt = "none") do={:set locRadioMAC [get [find where name=$locInt] radio-mac]} else={:set locRadioMAC [get [find where name=$locMasterInt] radio-mac]}
    :local locCAP ""
    /caps-man radio
    :do {:set locCAP [get [find where radio-mac=$locRadioMAC] remote-cap-identity]} on-error={:put "ERROR - $locMAC - $locRadioMAC"}
    :local locIP   "noDHCP"
    :local locName "noDHCP"
    /ip dhcp-server lease
    :if ([find where mac-address=$locMAC]) do={
        :do {:set locIP   [get [find where mac-address=$locMAC] address  ]} on-error={:set locIP   "DCHP-Err"; :put "ERROR with $locMAC - Please check DHCP for duplicate entries"}
        :do {:set locName [get [find where mac-address=$locMAC] host-name]} on-error={:set locName "DHCP-Err"}
    :if ($locSignal <= -70) do={:terminal style varname} else={:terminal style none}
    :put "$[$fill $locMAC 19 " "]$[$fill $locIP 17 " "]$[$fill $locName 12 " "]$[$fill $locCAP 10 " "]$[$fill $locSignal 7 " "]$[$fill $locSSID 18 " "]$[$fill $loctxRate 11 " "]$[$fill $locrxRate 11 " "]$[$fill $locUptime 14 " "]$[$fill $locBytes 21 " "]$[$fill $locPack 15 " "]$locInt"
viewtopic.php?f=14&t=13947
