RouterOS v6.19
Описание каждой версии, обсуждение особенностей и недостатков
Dragon_Knight
RouterOS v6.19
 What\'s new in 6.19 (2014-Aug-26 14:05):
*) wireless - improvements for nv2 and 802.11ac
*) sstp - make sstp work on i386 as well;
*) ippool - improve performance when acquiring address without preference;
*) partitions - copying partitions did not work on some boards;
*) bridge - added "Auto Isolate" stp enhancement (802.1q-2011, 13.25.6)
*) ipsec - when peer config is changed kill only relevant SAs;
*) vpls - do not abort BGP connection when receiving invalid 12 byte
    nexthop encoding;
*) dns-update - fix zone update;
*) dhcpv4 server - support multiple radius address lists;
*) console - added unary operator 'any' that evaluates to true if argument
    is not null or nothing value;
*) CCR - improved performance;
*) firewall - packet defragmenting will only happen with connection tracking enabled;
*) firewall - optimized option matching order with-in a rule;
*) firewall - rules that require CONNTRACK to work will now have Invalid flag
   when CONNTRACK is disabled;
*) firewall - rules that require use-ip-firewall to work will now have invalid flag
   when use-ip-firewall is disabled;
*) firewall - rules that have interface with "Slave" flag specified as in-/out-interface
   will now have Invalid flag;
*) firewall - rules that have interface without "Slave" flag specified as in-/out-bridge-port
*) firewall - rules with Invalid flags will now be auto-commented to explain why;
*) l2tp - force l2tp to not use MPPE encryption if IPsec is used;
*) sstp - force sstp to not use MPPE encryption (it already has TLS one);
*) sstp - make it work for x86 systems
*) winbox - added dual PSU stats in health menu
*) ipv6 - Gre6 can now correctly fragment large packets
*) simple queue performance optimisation/improvement for multi-core RouterOS devices (especially CCR)
Загрузка:
mipsbe - CRS series, RB4xx series, RB7xx series, RB9xx series, RB2011 series, SXT, OmniTik, Groove, METAL, SEXTANT;
x86 - PC / X86, RB230 series;
ppc - RB3xx series, RB600 series, RB800 series, RB1xxx series;
mipsle - RB1xx series, RB5xx series, RB Crossroads;
tile - CCR series;
mikrotik.com >> download - Официальная страница загрузки;
ChangeLog v6 - Список изменений в 6 версии RouterOS;
Замеченные проблемы:
1) Не корректная работа маркированных пакетов >> viewtopic.php?f=1&t=5717
2) Не работает NTP-Client
3) Пока не заметил...
DeLL
Обновил тестовый стенд с настроенным VRRP - сломалась работа данного протокола, глючит неподеццки, откатываюсь обратно на 6.18
nurikzaripov
Обновил у себя. Функции PPPOE сервер, OSPF, VLAN'ы 4, firewall порядка 60 правил. 4 дня полет нормальный. Заметил что загрузка в часы пик меньше стала на проц
-user-
подскажите пожалуйста в чем заключается?
а то я без него дату не мог настроить, каждый раз при выключении/включении слетала.. а с ним все норм, так вот обновил прошивку - и с датой все норм... и вроде пишет что получает время и дату... может не туда смотрю?
Dragon_Knight
-user-, Проблема только на CCR. На других устройствах всё работает...
Суть проблемы такова, после включения NTP-Client внизу светиться Started и ничего больше не происходит. Ждал почти неделю, когда как на 2011 модели сразу надпись Started поменялась на Synchronized и время действительно было синхронизировано.
-user-
Dragon_Knight писал(а):...
Не хочется флудить... нету кнопочки под форумчанином - "поблагодарить"...
но сказать надо:
СПС. :a_g_a:
