Подскажите плиз по логам у меня с провайдером часто отвалы инета настройки клиента привожу и логи у кого глючит клиент в микротике или сервер у провайдера ?
add disabled=no interface=ISP_Rubin use-peer-ntp=no
20:26:05 dhcp,debug,state Dhcp_: dhcp-client on ISP_Rubin entering <renewing...> state
20:26:05 dhcp,debug,packet Dhcp_: dhcp-client on ISP_Rubin sending request with id 4057741078 to 172.16.250.200
20:26:05 dhcp,debug,packet Dhcp_: ciaddr = 10.200.10.162
20:26:05 dhcp,debug,packet Dhcp_: chaddr = 4C:5E:0C:2C:FC:18
20:26:05 dhcp,debug,packet Dhcp_: Msg-Type = request
20:26:05 dhcp,debug,packet Dhcp_: Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server
20:26:25 dhcp,debug,packet Dhcp_: dhcp-client on ISP_Rubin received ack with id 4057741078 from 192.168.101.39
20:26:25 dhcp,debug,packet Dhcp_: ciaddr = 10.200.10.162
20:26:25 dhcp,debug,packet Dhcp_: yiaddr = 10.200.10.162
20:26:25 dhcp,debug,packet Dhcp_: siaddr = 172.16.250.200
20:26:25 dhcp,debug,packet Dhcp_: giaddr = 192.168.101.39
20:26:25 dhcp,debug,packet Dhcp_: chaddr = 4C:5E:0C:2C:FC:18
20:26:25 dhcp,debug,packet Dhcp_: Msg-Type = ack
20:26:25 dhcp,debug,packet Dhcp_: Subnet-Mask = 255.255.0.0
20:26:25 dhcp,debug,packet Dhcp_: Router = 10.200.0.254
20:26:25 dhcp,debug,packet Dhcp_: Domain-Server = 10.101.100.254,91.214.176.174
20:26:25 dhcp,debug,packet Dhcp_: NTP-Server = 192.168.100.100
20:26:25 dhcp,debug,packet Dhcp_: Address-Time = 300
20:26:25 dhcp,debug,packet Dhcp_: Server-Id = 172.16.250.200
20:26:25 dhcp,debug,state Dhcp_: dhcp-client on ISP_Rubin entering <bound> state
20:32:48 dhcp,debug,state Dhcp_: dhcp-client on ISP_Rubin entering <renewing...> state
20:32:48 dhcp,debug,packet Dhcp_: dhcp-client on ISP_Rubin sending request with id 4057741078 to 172.16.250.200
20:32:48 dhcp,debug,packet Dhcp_: ciaddr = 10.200.10.162
20:32:48 dhcp,debug,packet Dhcp_: chaddr = 4C:5E:0C:2C:FC:18
20:32:48 dhcp,debug,packet Dhcp_: Msg-Type = request
20:32:48 dhcp,debug,packet Dhcp_: Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server
20:33:49 dhcp,debug,packet Dhcp_: dhcp-client on ISP_Rubin sending request with id 4057741078 to 172.16.250.200
20:33:49 dhcp,debug,packet Dhcp_: secs = 60
20:33:49 dhcp,debug,packet Dhcp_: ciaddr = 10.200.10.162
20:33:49 dhcp,debug,packet Dhcp_: chaddr = 4C:5E:0C:2C:FC:18
20:33:49 dhcp,debug,packet Dhcp_: Msg-Type = request
20:33:49 dhcp,debug,packet Dhcp_: Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server
20:34:41 dhcp,debug,state Dhcp_: dhcp-client on ISP_Rubin entering <rebinding...> state
20:34:41 dhcp,debug,packet Dhcp_: dhcp-client on ISP_Rubin sending request with id 4057741078 to 255.255.255.255
20:34:41 dhcp,debug,packet Dhcp_: flags = broadcast
20:34:41 dhcp,debug,packet Dhcp_: ciaddr = 10.200.10.162
20:34:41 dhcp,debug,packet Dhcp_: chaddr = 4C:5E:0C:2C:FC:18
20:34:41 dhcp,debug,packet Dhcp_: Msg-Type = request
20:34:41 dhcp,debug,packet Dhcp_: Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server
20:35:11 dhcp,debug,packet Dhcp_: dhcp-client on ISP_Rubin received ack with id 4057741078 from 192.168.101.39
20:35:11 dhcp,debug,packet Dhcp_: flags = broadcast
20:35:11 dhcp,debug,packet Dhcp_: ciaddr = 10.200.10.162
20:35:11 dhcp,debug,packet Dhcp_: yiaddr = 10.200.10.162
20:35:11 dhcp,debug,packet Dhcp_: siaddr = 172.16.250.200
20:35:11 dhcp,debug,packet Dhcp_: giaddr = 192.168.101.39
20:35:11 dhcp,debug,packet Dhcp_: chaddr = 4C:5E:0C:2C:FC:18
20:35:11 dhcp,debug,packet Dhcp_: Msg-Type = ack
20:35:11 dhcp,debug,packet Dhcp_: Subnet-Mask = 255.255.0.0
20:35:11 dhcp,debug,packet Dhcp_: Router = 10.200.0.254
20:35:11 dhcp,debug,packet Dhcp_: Domain-Server = 10.101.100.254,91.214.176.174
20:35:11 dhcp,debug,packet Dhcp_: NTP-Server = 192.168.100.100
20:35:11 dhcp,debug,packet Dhcp_: Address-Time = 300
20:35:11 dhcp,debug,packet Dhcp_: Server-Id = 172.16.250.200
20:35:11 dhcp,debug,state Dhcp_: dhcp-client on ISP_Rubin entering <bound> state
DHCP Client
настройки фаервола
add action=drop chain=input comment="drop invalid connections" \
connection-state=invalid
add chain=input comment="allow established connections" connection-state=\
established
add chain=input comment="allow related connections" connection-state=related
add chain=input in-interface=ISP_Rubin protocol=icmp
add chain=input in-interface=!ISP_Rubin src-address=192.168.10.0/24
add chain=input in-interface=!ISP_Rubin src-address=192.168.14.0/24
add action=drop chain=input comment="drop everything else"
add chain=output comment="accept everything to internet" out-interface=\
ISP_Rubin
add chain=output comment="accept everything to non internet" out-interface=\
!ISP_Rubin
add action=drop chain=forward comment="drop invalid connections" \
add chain=forward comment="allow established connections" connection-state=\
established
add chain=forward comment="allow related connections" connection-state=\
related
add action=jump chain=forward jump-target=icmp protocol=icmp
add action=jump chain=forward jump-target=tcp protocol=tcp
add action=jump chain=forward jump-target=udp protocol=udp
add chain=forward comment=icmp log-prefix=icmp_ protocol=icmp
add chain=forward comment="accept from local to internet" out-interface=\
add chain=forward comment="accept to ap_mikrotik" dst-port=8291 protocol=tcp
add action=drop chain=forward comment="drop everything else"
established
ISP_Rubin
!ISP_Rubin
established
related
пологаю все же со стороны оператора ибо
А это всего то 5 минут, думаю что у него просто ДХЦП не вывозит такой нагрузки и потому вы долго не можете адрес получить
